kttdkt said:
I get how it works but I don't know what I would need to make one and I don't know how to put it together. Also is it worth it to take the time to clean it and fill it up for the sub-ambient temps?
There are a couple of good articles on the front page
about how to build a bong.
Is it worth it? Maybe. It is certainly not the most popular
water cooling technique. When you go sub-ambient you
are going to get more hassles than straight water cooling.
With a pelt you have mounting and condensation issues.
With a bong there is usually no condesation problem
because in a normal home you can go about 7C below
ambient before condensation shows up. UNLESS your
bong is putting out so much water that the humidity
goes over 60% or so.
I'd bet that less than 20% of the guys that started with
a bong are still using them.
You bong guys want to step in here?
