Water cooling!!!
MikeL
I think the pump I just got sucks! it only pumps 18" and thats not good any other places I can get some from?
18" is not necessarily bad depending on what you are tryying to do. If you are fitting everything in your case, 18" is very workable. If you have long stretches, then 18" will not fill the bill. You must remember that the 18" is usually lift, and not distance, and plan accordingly.
well Shadow said use a smaller hose and it should pump better. The hose that came with it was 1/2 he told me to get a 3/8 hose.
