- Jun 21, 2001
ok.. im totally new at this kinda subject.......
i just finished building a system....
Celeron 500
416megs pc-133 cas2
30Gig Maxtor ATA100 7200rpm
Intel 815 chipset/vidcard ** eeewwww **
Msi 815PRO mobo
Yamaha 4x4x16
Acer 52X ide cd-rom
and i got 4fans/heatsynks in it right now... i got a Just cooler 60mm fan blowing on my cpu from the top... a just cooler pci cooler... a 486 cooler cooling my chipset... and some cheap heatsynk/fan cooling my celeron..
my celorie idel's at 29c's and full load its at 43c's..... what i want to do is slap some water cooling on my celorie, now what i need to know from you people ** hopefully ** is... do i need to insulate around/under my celeron?
and does this look like a good set?
Spek's on pump...
1046 Centrifugal Pump
Flow rate 300 l/h
Discharge head 1.20 mWs
Power consumption 5 W
Inlet for the hose Dia. 13 mm
Outlet for the hose Dia. 11 mm
Dimensions L x W x H mm 145 x 75 x 103
ok.. can anyone help me?
Edit: rong smiley
Celeron 500
416megs pc-133 cas2
Msi 815PRO mobo
Yamaha 4x4x16
Acer 52X ide cd-rom
Loading…
amidyfreak.50megs.com
Loading…
Loading…
Loading…
Spek's on pump...
Flow rate 300 l/h
Edit: rong smiley
