- Jan 4, 2001
- Northern VA
I have some question concerning the right water pump for a system.
First off, what is the ideal GPH flow rate for a waterblock? I'm assuming that too low a flow will not take heat away, and too fast a flow might not allow the water to absorb and remove the heat...is this correct? If so, is there an ideal flow rate through a waterblock?
Second, if your running a resevior outside of the case, what size pump would be ideal?
I know the GPH rate drops due to hose height. What if your pump was mounted high though, would that still happen even iwth a few feet of tubing running down?
Thanks for the advice....I need to pick a pump by the way
Using my big resevior I found for free, want to put a submersible pump in it, just need ot know whats enough and whats too much.
Mike
Mike
