BlakeN (Jun 04, 2001 10:22 a.m.):
Ok I don't have anything to add to this accept to say that overclockedpc is completely wrong.
How water cooling works 101.
Lets say at 100gph the water pics up 10 heat units (this is all gestimation) and if gets to the radiator and gives off 10 heat units
Now at 500gph the water only pics up 2 heat units and gives off 2 at the radiator. but since the water is moving 5 times faster its still transferring 10 heat units in the same amount of time.
So why do you care if its 100 or 500? Well if the water is only carrying 2 heat units at a time then your water temperature is 2 heat units higher then ambient not 10.
This whole "got to give the water time to cool down" Is totally wrong because your only looking at one side of it. Sure the water doesn't loose 10 heat units at a faster speed like it would at a slower speed but it doesn't pick up 10 either.
