- Jul 17, 2009
- Kentucky, USA
Hey. I am completely new to water cooling, and had a few questions. I have a AMD Phenom II X4 965 BE (125watt) running at stock 3.4GHz. Recently (had the CPU for about a month now) I have started having overheating issues while gaming and rendering CAD images (using 3Ds Max, which uses 100% of the CPU for hours/days at a time). I have purchased the Zalman CNPS9900 NT air cooler, but it doesn't seem to bring the temps down much (compared to stock fan). So far with the Zalman it seems to idle at about 35C or so, and gaming brings to 45 or so (will do more tests in the next few days). The AMD specs say that the max temp for this CPU is 60C.
I am hoping to OC this CPU sometime to about 4.0-4.5GHz, and don't think my current cooling setup will do the trick (I don't know a lot about OC'ing either, so have no idea what rise in temps I should expect. Just wanting to be safe). So here is my question (finally to the point lol):
If I want to do an OC (at least to 4.0GHz, maybe more), will I need to get a liquid system for cooling, or will my current fan do enough? If so, what cooler would you suggest (cheaper is better, but can swing for quality). I really can't afford to burn out my CPU, so any suggestions would be great. Thanks for your help.
