Water vs Air for my new i7
WildMonkey
I have an old Koolance PC2-C system that I have been up keeping for years.
I'm upgrading to a new i7 system and not really big into overclocking anymore, I mean I will but don't really care to find out it's limits or running it a borderline frying temperatures so I can get that extra 2 points in Futuremark benchmarks.
So my question is whether it would be best to just buy a 1366 cpu block for my old system or just dump it and get something like a TRUE.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
I cant imagine a system from 2002 would be ableto keep an i7 with HT on cool. I would ditch it (the entire case), get another, and a TRUE or Prolimatech Meglahems (or however its spelled).
hokiealumnus
Water Cooled Moderator
I'd dump it and get a Megahalems or TRUE as suggested. Water cooling and air cooling have come a long way since 2002. Modern air coolers will trounce anything that system can do. Hey, on the plus side, you don't need to worry about leaks. :)
Neuromancer
Tau'ri
I got a nice deal on a WC loop for my i7. and must say. WAY WAY better than air cooling 20+C load difference and much quieter (until I crank it up to get that 1% better performance) . i7 is a blast furnace when OCed.
Apogee GTZ, BlackIce GTX 480, 655 pump Swifttech res
I had to buy some masterkleer tubing at .49 cents a foot, some new clamps, and some fans. (I went big and got UltraKaze 3Ks) in retrospect, I would have gotten something slower that runs better undervolted. But the price was very good, and the perofrmancei phenomonal. Chill air setup before with a super loud panaflo fan I was hitting 80+C. Now if I really push it I can hit 60C. (65C with fans on low speed)
Once I clean the block and rad next week, I expect temps to get even better :)
Daddyjaxx
Ormond Beach, FL.
I have about the same setup as Neuromancer, except I have two MR320's and am cooling my 275 GTX. This is what a good watercooling system can do with an overclocked I7 and GPU playing Crysis for an hour. Once you go water...it's really hard to go back.
Conumdrum
Small town Emlenton, PA
A nice newer i7 at stock speeds is just fine with a decent air HS. One that allows adding your own fans. Two quiet 120's in push pull with a good air HS in a good air ventilated case is more than enough.
You start adding massive GPU's to the case with the GPU fan noise? Ack...... One reason lots go water.
