Waterblock equipped with HSF?
asmodean
Senior Member
Finland
My socket is broken, so I'm propably going to take some measurements of the block & mobo and have a suitable copperplate made. I was thinking of having a heatsink attached (Pep66t) to it, with a fan ofcourse. Has anyone done this? Effects? I know it works as a small backup system atleast.
Thanks in advance.
AMDGuy
asmodean (Jul 11, 2001 10:58 a.m.):
Thanks in advance.
There's an article on in the watercooling section about this. It seemed to work good as a backup. The guy turned off the pump and his temps still stayed within spec.
asmodean
asmodean
Senior Member
Finland
Thanks for the fast replies! I'll go check it out now.
Edit: I had that same idea as that bacatá site, but for a blorb, using coiled copper tubing. Petar Lazarevskis article is what I meant, but it sadly doesn't tell what kind of difference in temperature there is when the water is running.
asmodean
asmodean
Senior Member
Finland
If someone has that waterblock from ochideout or the aqualstealth heatsink-clip, could you tell me the difference in temperatures with and without fans?
Thank you!
Fjeld
AMDGuy (Jul 11, 2001 11:04 a.m.):
Thanks in advance.
I did it that way, but mostly for a great look, and an easy attach of waterblock in combination with a modded clip. And the fan was needed due to mobo demand for this. But the thing works really nice, and give me a backup, if the pump should stop. Got a bigger picture of it all, if you want :)
[email protected]
