We've all heard how great Cathar's waterblock is, and many of us have vowed to produce a better performing waterblock than his.
I put forth a challenge. There should be a waterblock shootout to determine the (current) best waterblock. Testing shall be done by an independent 3rd party. (Possibly someone who already has one of Cathar's blocks?) Strict standards need to be adhered to. Ambient temp, tubing, radiator, pump, initial water temp all need to be constant between tests. All blocks should be able to mount on a Socket A motherboard. Let's set a date of Dec. 15th for the testing to begin.
Since we're looking for the best of the best, and testing takes both time and money, I'm going to set a standard. If your block cannot perform within a few degrees of a Maze3, don't send it. If you don't know if it does or not, buy a Maze3 and see.
It will be up to the tester(s) to determine whether to allow direct die blocks or not. Builders, if you want your blocks back, you will have to pay for return shipping. All blocks shall be eligible to be tested, no matter how they were manufactured. The only thing being tested here is performance.
Who volunteers to be the independent third party tester? Anyone have a CPU die simulator? Note: If we are unable to find an independent 3rd party tester, there will be 2 seperate tests ran, at seperate locations and performed by different testers, in order to verify the results.
Possible testers:
1. Neomoses
2. JFettig
What waterblock builders are interested in joining this competition? Who thinks their block is deserving of the title "Coolest Waterblock in the World"?
Competitors:
1. Neomoses
2. JFettig
3. Liss
4. The Overclocker
5. Albigger
6. Fragn'stien
this post will be updated with lists of possible testers and competitors.
Good luck to all, and let's raise the bar!
Possible testers:
1. Neomoses
2. JFettig
Competitors:
1. Neomoses
2. JFettig
3. Liss
4. The Overclocker
5. Albigger
6. Fragn'stien
