tighten it so the springs are fully compressed. as long as you tighten them evenly the core wont crack. tigheten one a half turn then the next then the next and next and so on until its fully tightened
thats good because i forgot to order a shim and i don;t feel like waiting a week for one will i also get better temps w/o a shim and my vid card has no mount holes so should i use epoly to put it on and grim what are your temps
