Watercooling gear for sale!
Squeebee
Hey All;
I have a Slot A Athlon watercooling set with GFD for sale on eBay, which I
thought I would see if anyone is interested in. The URL for the item is as
follows:
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1229741602
The full kit consists of the following:
Waterblock - made by Overclocker's Hideout, this unit is made of
adonised aluminum, so it will not rust. Hose nipples use 3/8" ID hoses.
Radiator - Customised heater core, lots of surface area for greating
cooling capacity! Comes with a 120mm fan for air flow. Input is 3/8" ID
hose, output is 1/2" ID hose. Output connector is swappable to 3/8" ID hose.
Resevoir - 4" cube, uses a gasket rubber seal at cover, has input brass
nipple for 1/2" ID hose (matches output from radiator), with 3/8" ID brass
nipple for output from pump (Pump not included) with internal hose to attach
to pump with 1/2" ID pump (standard pumps will connect to the 1/2" ID hose
used inside the pump. Pump is not included as it is now in my next project.)
Golden Fingers Device - Northwind Computers GFD 3.0
Hoses and Clamps - This set includes all the hoses and clamps needed to
assemble your system in a full tower, all you need add is the pump and
processor!
Check it Out!
Mike
