- Aug 7, 2002
Well, finally got my Maze 3 shipped......
Anyways, system is running great, here's the materials i'll have pics to show in a few days .
What i did is copied the design of the EXOS and built it to my specifications.
It's 24 " long by 8" by 8". on top i have a Sunon 120 mm 108 CFM on a rheostat (knob on top), plus a green led to indicate pump is running.
What i did was make the box out of sheet metal and then paint it black and put some car door molding around the top and fan opening. The top velcroes to the box.
Inside the box i made a relay in a project box that is sealed waterproof, it is also velcroed on bottom of box, it also powers the green led on top. Inside the box you also have the Eheim 1048 pump, a reservoir i made out of a waterproof electrical box with an opening on top and side entries for water. Also in there is a Chevette heatercore that sits just below the 120 mm fan.
Everything lays out perfect in there, important to note everything in there is siliconed to death plus wrapped with electrical tape for good measure. There are 3 holes in the back, 2 for the water in and out, the other one for the relay and fan molex connectors.
In the computer i have the Maze 3.
This is one of those Chieftec Aluminum with full size side windows.
I got to admit i was skeptical as to the cooling results. I am in my infancy here but so far temps are :
Ambiant : 21
MOBO : 25
CPU Idle : 33
CPU Load : 35 wwwwwwweeeeeeeee
Ambiant : 21
MOBO : 25
CPU Idle : 33
