- Mar 24, 2001
- Staten Island , New York
I currently have a Global Win WBK-38 hsf w/delta 6800 rpm fan 37cfm and my temps are 47c @ idle for cpu, from 1.4 @ 1.53Ghz .My motherboard temp is 24c.I have the AquaStealth 2 Watercooling kit with the biggest radiator beCooling sells and a rio 180 water pump ,copper ,jagged edge waterblock. I know from experiance with this watercooling kit when I had my 1.2Ghz Athlon @ 1.575Ghz my comp temps where about 3-4 c lower then my global win hsf.Is there a mod I can use to make my watercooling kit work alot better so I can get my 1.4 @ 1.7 = ) or higher I currently have the AYHJA-K stepping.I can't seem to get all the air out of my watercooling system either its pretty hard. I have a radioshack 4700 rpm 120mm fan on the radiator also.If there is also any air cooling mods I can do thats cheap please reply with that too.Theres a huge 12inch fan on the side of my case blowing air in my case to keep temps on mobo and cpu as they are now.Thanks for the help.
ReTiCuLeX G)Ds
ReTiCuLeX G)Ds
