I had a 1.2 cele @ 130fsb or 1575 give or take on an st6 using a
an sk6 h/s and slightly noisy fan.It would run prime 95 and 3dmark2001 at the same time forever..perfectly stable.I just installed an innovatek with the 159gpm pump watercooling system.I can now run prime 95 and 3dmark 2001 kinda stable
at 131 [email protected]. Not much of an improvement.
With the h/s fan combo and 130fsb I was at 1.775 volts.
My ambient temps range from 19c to 23c.
At an ambient of 23c my cpu temp under load is 40c-41c.
At best, I've dropped 2c at idle and under load.
This is disappointing and not quite what I expected.
The system is quiet, no bubbles,the water is moving, no kinks
in the hoses and the waterblock appears to be seated properly.
Does this seem right?
