Well, as a matter of fact age counts. When newer products with better performance are on the market then it's logical that if you got an outdated system it will underperform compared to newer systems or won't give you many score points in tests.
Anyway, your CPU is bottlenecking your system. Yea both GTX 1060 and RX 480 look good! You can wait untill GTX 1060 is out and you get the first benchmarks, compare that to the RX 480 and go for whatever you like most
Oops! Missed that. Thx Kenrou.
Hi,
Back again, i have been told that if I want to run my system as I do underneath out of site out of mind. I should steer clear of custom water cooling as you need to be monitoring fluid levels. AS my case doesn't have windows and it's underneath my desk that is not possible. I've been pointed towards a Swiftech H220 X2 Prestige as plug and play no maintenance etc option. Just want to find out if that good advice?
Thanks
Haider
I have the lepa exllusion 240 AIO cooler that is refillable/expandable/drainable but also comes prefilled and you don't have to touch it if you don't want to. Ran a year and never dropped at all in the fluid levels. I'd say do what's comfortable then go from there. If you can find an AIO that you can DIY with that could be an option as well. But also, unfortunately like me, if you go AIO your pretty much out that expense if you decide to go a full custom loop like I have recently.
Thanks I'll take a look into the lepa exllusion 240...
Hi,
Thanks
Haider
