Well i have read many posts concerning watercooling, and
have decided on that route,
I have a few questions that i cannot find answers to
1. How is the radiator mounted ? i'm planning on getting a Kit,
Leufken kit , i see their radiator placement , how is that put there ? zip ties ? screws ?
its on the lower bottom front of case in front of the reservoir
2. also cutting the Bottom Front metal grill i think would help to increase air flow, (after i cut the plastic cover off ,what tool is best, (thinking about buying a dremel) or how did you do it.
I have a Inwin Q500 Case
Thanks For Everything
