Watercooling Setupt, how does it look?
Bobaroo
Jersey
Watercooling Setup, how does it look?
Waterblock – DTek TC4 rev2
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=11
-$45.00
Pump – Via Aqua 1300 370gph Pump/Reservoir
http://www.aquastealth.com/index.asp?PageAction=VIEWPROD&ProdID=34
-$46.99
Radiator – Pro-Combo -Black
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=17
-$46.99
Fans -120mm Panaflo M1A
http://www.aquastealth.com/index.asp?PageAction=VIEWPROD&ProdID=45
-$15.00
Tubing – ClearFlex 60
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=94
-$1.50/ft(10ft)
Total - $168.50
The only thing I am not sure of is the liquid an additive to use. I will have distilled water, but what else? I don't want my tubing to look all ugly and foggy due to water wetter.
necromanx13x
LI, NY
I would personally recommend getting the Dtek Whitewater waterblock as it performs better than the TC4 and is only slightly more expensive. Everything else looks good though I dont really know much about the pump. As an additive i just use 10% antifreeze and its working just great.
B
Bobaroo
Jersey
Well I was looking at the whitewater, but I would rather have 2 barbs instead of 3, to keep my case less cluttered.
nikhsub1
Unoriginal Macho Moderator
Los Angeles
I agree with the WW.... It won't be much more clutter, as you join the 2 outlets with a Wye connector, let me dig up a pic of my old setup... I would strongly suggest spending more on a pump, the VIA's are OK, but not great. If you were to get an Eheim 1250, you won't ever need to worry about the pump. Even the 1048 would work well.
Arkangyl
D-Tek has a 10% off sale through Jan. 1st.
You can get their FLowmaster XT kit with a Whitewater block (+$10) and a Hydor L30 pump (-$10 to even things out) for $200, -10% and its $180 for a complete kit that has everything you need minus the distilled water and in exchange for a few more $$$ you get a BETTER block and a BETTER pump...
If you opt to stay with the TC-4 the kit drops to $190 which is $171 after the discount. not a bad deal eh?
necromanx13x
LI, NY
Yeah I have the eheim 1250 and I love it. Its definitely worth the extra money for the noiseless operation and added reliability.
nikhsub1
Los Angeles
Nice! AS for the additive, I would suggest using 20 - 25% anti freeze for corrosion if you get an aluminum top. If you went poly, I would use 10% anti freeze to keep things growth free.
B
Bobaroo
Jersey
Hmmm, how much big of an increase in performance/decrease in temperature will the WW have over the TC4. For $10 more I may go for it, but if I don't order before Jan 1, then $20 may be a little to much
nikhsub1
Los Angeles
About 5C better than the TC-4.
johan851
Insatiably Malcontent, Senior Member
Seattle, WA
Enough of an increase to be worth the extra $5 or so, trust me. You'll get maybe a 4-5C temperature drop (with a decent pump), and it's difficult to get a drop like that by anything else than adding a second radiator or something.
I too would suggest a stronger pump - you can get a Danner Mag 3 for about that price.
Also, if money is a concern, you can get Clearflex 60 for $.65/ft at www.mcmaster.com. Look on page 85 under Chemical PVC tubing, 1/2" ID, 1/8" wall, 3/4" OD - that's Clearflex 60.
B
Bobaroo
Jersey
heh really? That much...sounds like I am going white water.
Does it come with the Y connectors or do I have to buy them?
