Hi everybody,
I'm new at watercooling refrigeration systems and I have read all posts about that, but still needing some help.
I have an Intel i7 2600K processor mounted in a Cooler Master Elite 430 Black. I use my pc to work, image and video edition and sometimes to play games.
Don't have a huge budget for a RL system, so I'm looking for a basic kit or to buy that basic components on my own.
My main option are buying an XSPC EX240 Kit for 150$ but tje problem is that I don't like the two bay reservoir with the pump included, I prefer to get the pump and the res separated.
Other option is buy all the components (similar specs to EX240 Kit) on my own, and the problem here is that I don't know what pump should I buy, and if I pick one with similar specs to the XSPC 750 V4 is too much expensive (like 80-90$).
What I should do?
What specs are nice for a pump for a res, CPU waterblock and 240mm radiator?
Can I use for the system an aquarium pump?
Can the pump of the XSPC EX240 Kit afford adding another extra 150mm reservoir? (If it cans I'll buy the EX240 Kit + a 150mm res.
All help and suggestions will be helpful, thanks everybody!!
What I should do?
