Ok I am torn between which waterblock to buy.
Should I get the Aquastealth Jagged Edge block for $29 or the Maze2 block. THe maze2 block comes with all the mounting stuff. THe other block you have to buy the mounting stuff I think separatly. Also I am going to be getting my radiator from Aquastealth so it would be easier to get the Jagged Edge, it would be in the same order. Is the Maze2 really worth the extra money? $42 is pretty expensive...
Thanks!
Thanks!
