watercooling
Mr Snub
Im building a new xp comp and im a newb to watercooling so
should i but the koolance or just get a danger den kit
also some suggestions for the danger den
tft
R.I.
Personally, i think it is a better learning experience, if you put together your own. You might even want to try to go all out and make your own block :)
occool
dangerden. it would cost more to make a block yourself than you could buy.
I agree. Buy the water block, this way is faster and easier. Do a little search online. See what you like. Radiator you can buy from one of those online stores like Castetc, DangerDan etc or you can simply go to the auto shop stores and ask around. Tubing you can get from Home Depot. If you do it yourself, It’ll be cheaper and much more rewarding. Good luck and have fun with it.
res0r9lm
florida
Newguy123 said:
you could also buy the Mag 500gph water pump at petsmart for less then $50 or $40.
Newguy
there has been a few of people complaining about the danner pumps cracking where the fitting screw in. ehiem makes the best.
Newguy123
I've had mine for almost a year now without a problem. This computer runs everyday all day, I just turn it off at night then back on the next morning. So far running strong without any problems, and this pump is very quiet, therefore i have no complaints. I dont know much about the ehiem pump execpt its more the the mag. The mag was a good pump for the price so i bought it.
Newguy
ProPatria
Valhall
I got a Koolance and it works great, cpu [email protected] With air cooling it wouldnt go over 1507mhz, same thing with my gf3 card w/o koolance the gf3 card was running at 225mhz now the gpu is running at 250mhz :)
/ProPatria
res0r9lm
florida
vinyl lines get hard after a while and are prone to leaking. putting radiator after block is how most people have thiers setup. not really sure it makes a difference though.
res0r9lm
florida
/ProPatria
how about some temps. what vcore are you running?
ProPatria
Valhall
it says 31c (since i live in sweden we dont use F) but its 89f on the cpu water block :) and i have it at 1.85/3.80, havent tried to push the cpu any higher then 1666mhz.
/ProPatria
res0r9lm
florida
/ProPatria
celsius is what everbody should be using anyway according to post guidelines. those are darn good temps if it's uderload add a little bit of vcore to that and you might get to 1700+. I get 40c @ 1668 w/ vcore 1.97 but plan on going watercooling in the near future. haven't had the time or money been build more systems for folding instead of focusing on one. atleast now I know what temps tp expect.
ProPatria
Valhall
before i had the koolance i used a taisol with a 60mm fan on (dunno if you call it mm in America ?) then my cpu temp was up over 50c idle and like 55c full load. And now i get around 28c idle and 32c full load, with the fans running at half speed (koolance call it "mode 2")
Im really happy with the koolance case, my buddy got a vapochill and thoes are away more expencive, and he runs his [email protected] at like -10c, but it wount do any more then that, and even if mine wount go any higher then 1666mhz im still happy cause they koolance cost around $299 here in Sweden, and a vapochill costs $650 and the extra money just isnt worth 34mhz :)
Only thing bad i have to say about the koolance is the look, they could have ade a cooler looking case :) www.koolance.com
/ProPatria
Mr Snub
Mr Snub
thanx,
i think i will get the koolance and water the cpu and gpu
once i egt used to it i might grade
[EG]~NaTz~
pittsburgh pa
uhhh everythingmentioned i will comment
[email protected]
well guys i have heard that with the raidiator after the block is better, they say it lessen the heat lvl minimally. uhh i would also suggest building your own system. it is much cheaper. also a raidaitor runs about 28 dollars where i live thats at advanced auto parts just ask for a transmisson cooler. it will fit 2 120mm fans almost perfectly. if you dont want to machine a block ive heard of people sealing there heatsink in plexi glass or whatever and running whater over it (i thin that its riskier than just a block).if you go and build your own cooling system run it for 2 days in the tub to check for leeks (rmember to clog the drain or else you wont know if it leeks at night or something).i am experimenting right now myself.
ProPatria
Valhall
*lol* "its much chreaper" uhmm.. i dunno what kind of components you would get for a price cheaper then $299, but i for one would not want them :) Before i bought my koolance i looked at price/preformance and i found that koolance was both cheaper and preformed better then any home made watercooling system, that is if you dont have a peltier on it.
About the raidiator use common sense, fans blow on the raidiator that the water runs thru and there is where it gets cool, then it hits the cpu block getting warm then back to the water tank mix with the water ther and go to the raidiator again. Now if you place the raidiator after the cpu the water will get cooler after it have been in the block over the cpu, go in to the tank mix with water that have been standing still for a little while and then to the cpu again, it will lose some of its cold doing that, now just so you know what i mean, its less then 0.5c it will lose on doing that, but it will show up if you just a digi temp.
/ProPatria
[EG]~NaTz~
pittsburgh pa
propatria read it
hey that would all depend on the size of your resovior and if your resovior was cooled or not min is in a refridgerator like one with food and pop in it. plus what if you didnt run a resovior and depended purely on a raidator. a constant loop. then again the room tempurtature can change a lot. the chemicls in the water. is it tap or well water, maybe even perrier. there are two many variables to the situation that it would depend more on them than its position.
