ok guys, I have two dangerden cube radiators and a few feet of tubing, the 200gph pumps just arent going to cut it here, anyone know of a inline pump that will flow something like 300gph and has the 3/8" fittings and still fit in my case?
If I were you I would use a mag 5, which does 500gph. It has 1/2" fittings on each side, so just get a couple of plumbing parts at HD for like $3 to reduce those to 3/8" hose barbs.
I run a Nursery Pro 650 with one Cooling Cube. Restricting the flow does not lower the temps. What does this tell you?
BTW, the Nursery Pro 650 is the same pump as a Danner 700. Nursery Pro rates the flow at 1 foot, Danner rates the flow at no head. Kinda sneeky on Danner's part.
