- May 16, 2001
I just cobbled together my own H2O setup and have it running on my desk for the day to check for leaks before i actually install it.
The pump is a magdrive submersible Rio 600(?), the 200GPH model. Currently it sits approx. 10" from my monitor and produces noticeable flicker on the monitor when viewing something with a light colored background.
Now obviously both magdrive and oldschool pumps operate on the principle of a fluctuating magnetic field to rotate an armature of some kind. Data stored on harddrives can be corrupted by such fluctuating magnetic fields.
What I want to know is have any of you with watercooling experienced any sort of loss of data in your systems? Should i be concerned? Is the field strong enough to do damage?
What have you done to prevent data corruption? And also, whether u ahve expereinced a problem or not, how far away from your harddrives are u placing your pump?
What model pump do u have? Is mine radiating abnormal amounts of radiation, or is my monitor(KDS 19", not flat, pretty cheap) just sensitive?
My current plan call for the pump to be placed 4-6 inches from the nearest HDD. I cannot really place it much farther away due to the fact its a midtower case already populated by 2 CDROMs and 3 Harddrives.
I intend to experiment wrapping my reservoir with Al foil when i get home.
