- Sep 15, 2007
- Small town Emlenton, PA
Depends if you want a bay res or a regular res attached to the pump. They both work fine.
Well, I got an answer.. They simply told me that the particular card is not a reference card and they don't support it. Just that...Should I just go for a 2gb GTX 770 which is supported? Or what? That card seemed really nice for her price
Photon will not fit directly onto any pump, has 3 g1/4 ports on the bottom. so you have to plumb it in.
If you are tight on space then the monsoon may be a better fit.
I already told ya, you're going to be paying close to a 770 classy hydro. You might need $30-$50 more for it. I would do it. Up to you sir.
Did some research now that I got some spare time. GTX 770 Dual classified hydro copper costs 630$ at EVGA's site.... With that money, I can almost get 2x GTX 770 2gb SC on SLI...
Sry for double post, but where can I buy the wb for my GPU elsewhere than the XSPC site?
