WC setup questions
z0n3
Hoosier Land
Over the summer I have been getting the parts to build a new computer and decided to make the move to water cooling. I ended up buying a Switech 22600B kit(so no water block), a swiftech 6002 cpu block, swiftech mcw50 chipset, and swiftech mcw20 gpu. But recently my brother sent me a 8600B kit and now I have that also. SO my question is what to do with this new kit. Should I-
A: Use both res and pumps from the kits in the same loop.
or
B: Start a second loop to cool the processor.
or
C: Buy a TEC and cool it with a second loop.
Also what order should I set up everything in for which ever you reccomend.
yeah try to go with A then put a pelt under the processor water block.
but the radiators might not be big enough to dissapate all that heat
so you might not be able to go with pelts but just the regular water should work just fine.
~Magick_Man~
