- Nov 7, 2004
I booted up my PC this evening and I came across a rather unusual noise it sounds like a loud clicking sound but at first I thought it was 1 of the 180mm fans that is in my case and it was hitting something as it was spinning, but looking up at my monitor I got SMART disk failure to my WD 1TB HDD. I rebooted the PC and it wouldn't load up Windows even though it's on my Crucial 128GB SSD so I disconnected the WD's SATA cable and rebooted Windows booted up fine so since SATA is plug n play I reconnected the SATA cable to the WD and I got the same noise from it but the drive loaded up fine perfectly fine everything was there no read or write errors nothing, I even pushed it into the case even though it's locked in it's cradle tightly.
So to play it safe I ran Windows Disc Check it came back with no bad sectors and the drive loads up fine for caution to the wind I've backed up everything and moved my stuff to my other drives for safely if it goes it will only take my games with it which can be sorted as most are backed up anyway. I am baffled to know what it was as I've not really heard the noise before but if it happens again I'll record it, it sounds like maybe a head failure possibly.
