WD1200JB in Firewire cage formatting problems!
Nero
Brooklyn!
I just picked up a WD 1200JB, with the intent of replacing the 5400 60gb drive I've got in my Firewire enclosure. I replaced and installed the drive fine, and went about partition and formatting it. Because I need Mac compatability, I went with 4x FAT32 partitions. Now this is where is gets interesting. The drive itself is listed as 128gb. Now I found this odd, but went ahead and started making 32GB FAT32 partitions. Everything went fine until I got to making the last partition, where it keeps freezing at the 49%. I backed off the size of the last partition to 24gb, and then it froze @ 65%. I tried using NTFS on the last partition, but no dice. I'm baffled as to why there is a problem. The drive is well under the 137gb "barrier" experienced by my firewire drive's controller, so I assumed everyting would be ok.
Also, correct me if I'm wrong, but shouldn't the capacity of this drive be 117gb? Why would it be recognized as 128gb?
Assuming the drive likes being in that enclosure (i.e. has no porblems), and that your Mac can handle 32+GiB partition, have you tried a single partition?
I imagine the problem is with WinXP. And since you sound like you are using XP to format, it would be easiest to accomplish this by using a simple program like Partition Magic, and have the WD drive temporarily installed in your chassis.
I see 111.6GiB total on an older 5400RPM WD drive. I think you mean 120GB/120 000 000 000B. Though I would not be surprised to see size values vary between HDD families.
Me = idiot @ math. The actual capacity of my 120GB drive is 111.75GB (120 x 1,000,000,000 / 1,073,741,824 = 111.75 GB), though originally I though it was 117gb. What is even stranger is that the drive is still being detected as 128.00 actual GB.
I managed to successfully format 3 partitions for a total of 111.25 GB of storage (2 FAT32 and 1 NTFS).
The Macs I work with can totally handle FAT32 partitions greater than 32GiB, but Windows XP can't natively format paritions in FAT32 greater than 32GiB. I am going to hook the drive directly up to my mobo and use a utility other than XP's disk management to format the drive. If I knew exactly how to do it, I could also used Knoppix to format the drive without having to move the drive internally and install a 3rd-party utility.
Well, PartitionMagic and the various other partitioning programs should be able to work within Windows. I have not tried since I tend to make firmware/acoustic/speed adjustments when partitioning/formatting.
