- Aug 29, 2012
- Colorado
I've recently discovered a big issue between running speed test via web based applications and local applications. I've tested many brands and have come up with the same results but I will focus on Ookla for this post.
When I run the tests online I get between 100 Mbps and 200 Mbps. But when I run the downloaded applications I easily get over 800 Mbps. I am paying for the 800 Mbps Xfinity plan.
I have tried different browsers as well as adjusting throttling speeds in Chrome. No matter what I do, I continue to get sub 200 Mbps with online speed testers.
Attached are my Ookla screen shots for the web based and local applications. You can also see that I used the same server as well (Baltimore, MD Comcast).
Can anyone explain this to me?
TIA
My setup:
-Comcast Cable
-Arris G36 Gateway
-TP-LINK 24 port gigabit Ethernet unmanaged switch
-Trendnet 16 port unshielded patch panel
-Cat 6 cable
-Both computers are connected via ethernet
TIA
My setup:
-Comcast Cable
-Arris G36 Gateway
-Cat 6 cable
