Weekly stats.....
Basher
Senior Member
Mt. Pleasant Pennsylvania
I plan on converting the weekly stats sheet to a format similar to the daily's (basically the sheet grnerates all the table html code and all that is necessary is to paste that code in and then there is no frontpage formatting necessay, saves 3-4 minutes per page). My main question is how do you want the data displayed? The data will remain the same but I can do any formatting we want. What would you like to see?
I think you can use the same color coding you have used in the daily stats. (I suppose you are using the conditional formating of cells, so it will be very easy to just copy the format ;))
Also as you have done with the daily stats you could display 100 members per page instead of the 50 you are using now, that way you'll have less pages to do.
Good work, Sean. The stats pages are really good.
Sound good to me...the dailys are turning into an awesome display for our team. :)
Cy
