- Nov 4, 2008
I did a clean install of win7 to my new SSD. While installing the drivers, I noticed there was a new BIOS available (F8). I was still using F6, so I reflashed to F8. When I tried to plug back in my settings for my 4ghz overclock (200x20, 2:8 on the ram, 1.396v in the bios for 1.360v in windows, 1.29 VTT), and prime fails after a few seconds on 2 of the cores, and the other 2 fail after about a minute. That isn’t the strangest part though. Before the BIOS update, when running p95, 70-75c was reached on my 3rd core within 20 seconds, with the other 3 about 3 or 4 degrees behind. However, with the F8 BIOS, it never broke 52c. I went back into the BIOS and set the vcore to 1.425v and the vtt to 1.3v. Prime will run a small FTT test for about 5 minutes before giving a rounding error on the 4th core. The temperatures still don’t break 65c though. A blend test gives an error after about a minute. This CPU was previously stable at 4ghz at only 1.360v and was able to run prime95 for 24 hours without error. The only changes have been the SSD, new operating system install, and the BIOS update.
Did the new bios lose where the “0.00v” setting is on the vcore (hard to explain what i mean...think “tare” on a digital scale), and when I am putting in a vcore, it is actually putting in a number well below what I input? Has anyone else had a similar problem?
