I just purchased a 1.2GHz Celeron with stepping SL5Y5 and a Asus TUSL2-C motherboard rev 1.04 (Bios Revision 1012). My Current setup is Micron 256MB PC133 Ram, Geforce 2 GTS Video, Sound Blast Live 5.1 MP3+, Kingston KNE 100TX NIC, and NEC 5 port USB 2.0 PCI add on card. I currently did the volt mod and it will run stable at 1584MHz for a little while until it heats up. However once the front side bus is on 133/133/33 it will not post at 1600MHz?? However it will post at 132/132/42?? I just don't understand it?? I need your help in getting this thing to 1600MHz. What kind of RAM are you guys running in your setup? What kind of Heat sink fan combo do you recommend? I currently have a Alpha with a PEP66 fan on there and my temperature is right around 51-52 C and when at 1500 its 41-42 C.
Thanks
Thanks
