I just upgraded my computer yesterday with an E8400 and EVGA 780i mobo (along with other parts of course). So I got it all up and running and figured I'd check out my temps (since I added 2 more 120mm fans to my case). HWMonitor was showing me 72C on both cores idle with the proc underclocked to 2GHz (bios setting for idle I haven't changed). I got a temp gun out and started shooting anything I could get at the base of the heatsink since there is no way to get the proc itself and the max I got was 30C. I'm not sure what sensor it uses for the cpu temp in the bios but that also read 30C when I rebooted. I let my computer sit for half an hour off (also overnight later with same results), started up HWMonitor as soon as I could and it was at 70C cold. In HWMonitor I noticed there is a System temp, CPU temp and a temp for both the cores. The system is reading -64C and doesn't move so I don't know if that means I lack a sensor? The CPU temp reads 26 idle and 42 full load, and the cores are at 72C 77C max. So to make a long story short, does this mean my actual core sensors are wack, and if so would it be smart to RMA it (ie if I hit 50C actual will it think it's 100C an throttle down?)
PS I didn't run prime too long, but I did play games for hours straight with the same temp results.
