Hi!
I've got a weird problem (for me it is) that I wonder if you experts could help me to disentangle.
This is the hardware configuration:
Intel P4 (BX80531NK150G)
2x 256MB RIMM
Ati RADEON 7200 (1.5V)
-installed into-
Configuration1:
ABIT TH7II
Configuration2:
ASUS P4T-E
Symptom:
When the power supply is switched on, the computer immediately starts (!) and runs for about 2 seconds. Normally it would not start until a signal is given to the power switch on the motherboard, right! That's the first symptom that may be an important clue.
Second. When the power switch on the motherboard is put on, the computer starts (the onboard LED is lit, the fans spins etc.), but nothing else happens. No signals, no "POST" codes, no video output.
I have tested the CPU in another computer so I know that is working. The power supply is also working properly. What about the memory modules? I haven't been able to verify they're really working, but the same symptom appears with or without them installed anyhow, so it couldn't be them?! Apart from testing the components (to the extent that is possible for me) I have also cleared the RTC RAM in CMOS, plugged and unplugged the cords, testing each memory module; one at a time. It has shown no progress so far.
The same symptom appears with both hardware configurations.
What could be wrong?
Please help me
2x 256MB RIMM
-installed into-
Configuration1:
ABIT TH7II
Configuration2:
ASUS P4T-E
Symptom:
Please help me
