Yes, capacitor.. thank you, that's what I meant...
OK.. well I tested the second solder point on the Q36 chip with my multimeter and it read 4 volts... so I realized thats about even with the attenuated feed from the 12v rail... so it's fine... now I understand...
Thank you so much.. I'll give it a go tonight... yeah, jumper is a great Idea, if you could describe exactly what you mean it would be great... My Idea was to just use longer wires to connect the Pot and snip the wires if I need to disconnect, and I can always re-attach the wires or clean it up later... the imporant / difficult part is just getting a good clean solder on the two points..
thx again.
P.S. gonna have to remove my stock NB cooler from the SB... cuz it's covering the contact point.. hehe
thx again.
