went from evga 9500gt 512mb to xfx 9500gt 1gb and wei scores went DOWN???
dito
Vacaville, CA
i wanted to boost my vid memory a little and it was only $50, so i thought going from a Evga 9500gt 512mb to a XFX 9500gt 1gb, would either be the same or better, but my WEI score went from 5.3 DOWN to 4.9? what gives? i did have the evga overclocked some, but cant find a overclcok utility from XFX. any help, opinion??? thanks!
Old Thrashbarg
That was $50 wasted, honestly. There's not really any benefit from having more than 512MB on a 9500GT, and certainly not $50 worth of benefit.
But as for the score difference, did you possibly switch from a DDR3 card to a DDR2 one, or change to a different driver version, or anything else?
WEI scores seem to largely be based on pulling a random number out of the air, anyhow. My 8600GT scored a 6.7, and I've seen a GTX275 score a 6.5. I wouldn't worry about it too much.
ratbuddy
Yeah, bet he went from GDDR3 to regular DDR2 or something.
dito, neither of those cards is fast enough to take advantage of 512MB, let alone 1GB. Ask us before you make an upgrade in the future :p
You can grab Rivatuner (google it) to overclock the card.
dito
dito
Vacaville, CA
Guess it's going back to Tigerdirect. Ok so what vud card would you recommend for under$100
deed
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133305&cm_re=8800gtx-_-14-133-305-_-Product
This one is slightly better in some things and goes on sale often for less then the 8800gtx: http://www.newegg.com/Product/Produ...4130339&cm_re=9800gtx+-_-14-130-339-_-Product
This one goes on sale alot also for under 100:http://www.newegg.com/Product/Product.aspx?Item=N82E16814130469&cm_re=250gts-_-14-130-469-_-Product
When the 8800gtx is back in stock and since at defualt its under 100 I would snag it. Just destroyed the 9500gt in some game benchmarks by 30+ frames.
ratbuddy
Er, 8800GTX is kinda outdated at this point. 90nm GPU, and pretty hefty power use. Also, those other two cards you linked are nowhere near "under $100" :beer:
deed
The 8800gtx may be outdated but gets an average of 30-40+ more frames in games the nthe 9500 and beats the 9600 in alot of things.
And I do believe i mentioned that about they go on sale very often for under 100 dollars :)
ratbuddy
Assuming this card is for his 'rig 1' which shows the 9500GT now, that PSU only has a single 6 pin PCIe connector which was also part of my reason for saying "don't" to the 8800GTX which requires two. I'm sure the 450w Corsair unit could handle it, but I'm just not a fan of using molex->PCIe adapters.
And if they aren't on sale now, well, they aren't <$100 cards ;)
deed
My apologies ;)
ratbuddy
Whoa, hold on, something isn't right there. A 9600GT with GDDR2? I'd give that one a wide berth, personally.
What about one of these? 9800GT, $90, no rebates. Or here's a 4670 for $70, again with no rebates.
WTF? Why would they put DDR2 on a 9600GT?? No wonder it's so cheap, I shoulda noticed that.
OP, don't buy the card I linked :p
