pauldriver said:The only buggaboo is that the WD drives do not like high PCI bus speeds.
My Maxtor allowed me to run a FSB of 166 with no problems (41.5 Mhz PCI) whereas my WD only allows me a FSB of 153Mhz (38.25)
Bummer.
Paul.
SlowBurn said:
Just out of curiosity were you using the 1/5 divider? The reason I ask is because I'm running my Abit KD7 at 170 FSB and I'm using the 1/5 divider, and so far have had no problems. I even ran Prime95 for 10 hours with no errors whatsoever.
Bummer.
Paul.
WyrmMaster said:
Hmm, my WD will let me go to 169, i havent pushed it any farther than that, but it may go even farther.
SlowBurn said:I have an Abit KD7 and it has a 1/5 divisor, and as we speak I am running my computer at home (at work right now) at 175 FSB which would put my PCI at 35 MHz. I can't remember what is the highest you should run it. Anyone know?
pauldriver said:The point of my post was the the WD drives won't handle as high of a PCI bus as others, my Maxtor drives are fine at a 45Mhz PCI bus speed.
Those of you with a PCI speed higher then 38Mhz are either lucky, or not yet noticing your errors, the WD drives will sorta work for me at 40Mhz. Most of the time they are fine, but I would get the occasional disk lockup, most notably in disk benchmarks.
Paul.
