i have just make a water block out of a small heatsink and pollyurathane plastic sides, i have used silicon seelent to glue it all together, recken it will work? it wil be used to cool the celeron so wount be that hot
sounds like it could work if you did what i think you did, justmake sure... as always... to test the hell out of it before geting it near the good all mobo and cpu, unles you want to turn your case into an aquarium, hehe j/k
I think someone somewhere in some OC site or forum I've come across managed to put together a waterblock that is very similar to yours and it works fine. I recommend running it out of your casing for a whole day or two to check for leaks. Print a whole page of text with an inkjet so if there's any leak, you'll spot it easily when the text gets washed away.
