what about condensation
MasterClone
iowa :(
i checked the forum and i didn't really see any info about condensation of watercooled systems. maybe this gets asked every so often, but i just thought id check with the experts. :D
the last thing i need is to fry my new mobo and cpu.
Welcome To The Fourms !!
Water Cooling & Condensation is not a problem.
Condensation usually occurs when you're using a Peltier setup.
Extream Heat and Extream Cold put together = Condensation.
Regular H20 cooling is mostly room temp.
Peltiers and H20 work great together. That's when you need condensation protection.
Read some of the Beginners Guides on both topics.
You'll learn a lot !
Oh, and I'm no expert. I've jus had more mistakes than you. lol
:cool:
The quick answer: For the humidity level and temperatures
in most people's homes you can go about 7C below
ambient before condensation can form. That means most
bongs wont be a problem. Straight water cooling can't
be a problem ever. With pelts....look out!:)
thx for the help!!!
that link you sent was really helpful.
ive posted here a few times b4 and i must this is by far the best forum on the net.
