What about the temp with peltier
heavenly
Hi , I would like to now what the temps should be with a peltier and a PEP66T with two fans (Alpha's) at 5vlt
I see posts with temps going below zero and top 19/20 c , I have a [email protected] and with full load it goes into the lower 30's and idle it stay's at 5/6 C.
The pelt is a 80 watt and is firmly making contact with the core , between all parts is a thin layer of artic silver.
Any suggestions?? Thanks a lot.
wild_andy_c
NAKED Overclockers Unite! Senior
Milton Keynes UK
This is a very subjective question on a very subjective topic. It's a case of suck it and see.
Air cooled pelts alone are generally only as good as water alone cooling. i.e. a 10°c drop from air alone.
The only real super gains come with the combination of the two - that's when supercooling sub zero occurs. Especially when conducted using a vapour phase refrigerant.
H
heavenly
Hi [email protected] PC133 cas222 7/9
Temp idle is 4C and full load is 23C , The sys is stable as to now . Should i bother getting watercooling to?
I don't think the temps are gonne hold me back in further O/C??
B
BorisDaSpider
Guest
[email protected] 78Watt peltier,water cooled aluminum block Sitting hear with 3 browsers and mp3 playing and looing at mbm5 im at -35C Under load I might get it up to -5C
