nicholas70
- May 19, 2019
MSI Z390 MAG tomahawk
i7 9700k
rtx 2060
hxi 850w
corsair vengeance 3200mzh 16gb
So to make a long story really short I recently discovered my motherboard isn't supplying correct voltage to either my RAM or cpu or both. I know this because I've tested known good RAM and cpu and still get errors at factory settings running OCCT. Intel Processor diags will also eventually fail on IMC test on stock settings. I'm not running any OC but if I downclock the RAM slightly and disable turboboost the tests pass. So this brings me to my main question what are safe voltages for the VCCSA and VCCIO or SA/IO? I've been researching this for hours now but it seems everyone has different answers to this question and Intel's spec sheet seems to imply that IO voltage over .96(the default) is out of spec and would void the cpu warranty as well as risk degrading/damaging the cpu. While other sources I've found disagree on the matter and indicate safe voltages might be as high as 1.3 or as low as 1.15, so what is it already? Any help I could get here would be great as I kinda think RMAing the board could be a real pain, and I'm considering just limping along with this one until I can save up for a new better mobo but don't want to damage of void my cpu warranty.
i7 9700k
rtx 2060
hxi 850w
