If I'm not mistaken, IE is known to be bloatware direct from Microsoft to your home, and so well integrated into your Windows machine that taking it out is almost sure death. There are apps that remove IE from Windows and allow you to use Netscape or another program like Mozilla, which I strongly suggest if you're looking to reduce memory use. Either way, like I and someone else said, there's really only so much that can be done. I'm pretty sure the the task manager in 9x only displays programs and not tasks, like the above poster stated. To keep memory from being retained after you've closed an app, try keeping ones you don't use from starting in the first place. That way you'll have more memory while using things like Internet Explorer. If you're looking for better resources management, go for NT based OS's. But if you can live with it, there are things you can do to alleviate your dillema to a certain extent. Look around, and you'll find some good ones and some not so good ones. How much RAM and what type of RAM do you have? SDRAM really sucks. DDR is pretty much wasted on 9x. If you're putting around with only 128 MB of RAM, I'd suggest getting more. Windows OSs, no matter what they tell you, require a whole heap o' RAM. If you've got limited amounts of RAM, Windows will start using Hard Drive space as RAM, which is not only gruelingly slow, but is a very big resource waste. If you've got programs actually utilizing virtual memory when you're only using a few programs, get more memory or get an OS that will manage memory better.
Good luck
Z
