What are you running your AMD CPU at?
Bman1238
Disabled
arizona
Please give your
-Default CPU speed
-Overclocked speed
-Core voltage
-FSB speed
-Memory speed
-Idle and load temps
Thanks :cool:
HeXaDeCiMaL
Huddersfield
-Default CPU speed
1.733Ghz
-Overclocked speed
2.425Ghz
-Core voltage
2.00V
-FSB speed
211Mhz
-Memory speed
422Mhz (Dual Channel)
Idle ??? (its never idle always folding)
Load ~52C
orion25
Folding in memory of my dads, Tim B. & Mike B.
Alabama
--Default CPU Speed
1.46ghz (I think, it has never been there)
--Overclocked CPU Speed
2.205ghz For Now
--Core Voltage
1.65v
--FSB Speed
210mhz
Memory Speed
420mhz
--Idle Temp
31C
--Load Temp
38C
Other
+3.3v at 3.31
+5v at 4.97
+12v at 12.16
altec
polka dot ninja
Doylestown, PA
Highest stable (but the temps are too high)
Default: 1.46Ghz
Overclocked: 2.5Ghz
Core Voltage: 1.9v
FSB: 200Mhz
Memory: 400Mhz
Idle: 47C
Load: 57C
Usual use
Default: 1.46Ghz
Overclocked: 2.45Ghz
Core voltage: 1.85v
FSB: 200Mhz
Memory: 400Mhz
Idle: 41C
Load: 47C
slater3333uk
Suffolk, UK
-Default CPU speed - 2000mhz
-Overclocked speed - 2325mhz
-Core voltage - +5%
-FSB speed - 155mhz
-Memory speed - 310
-Idle and load temps - 34c idle 39c load
OrionRU
-Default CPU speed - 1.47
-Overclocked speed - 2220mhz( for not)
-Core voltage - 1.55
-FSB speed - 210mhz
-Memory speed - 420
-Idle and load temps - 30c idle 37c load
EspElement
-Default CPU speed-
1.83ghz
-Overclocked speed-
2.305ghz
-Core voltage-
1.95
-FSB speed-
200
-Memory speed-
[email protected] 2.9v
-Idle and load temps-
cpu:33c 39c
mobo:15c 19c
system:29c
this is with prime stable i can clock alot higher
still burning and clocking..... tring to get the AS3 with my new SLK900U i tried 2.2vcore at 1.5... and still couldnt reach 50C :(
Mustanley
EspElemnet, those are nice memory timings. I have the same memory, but the best I can manage at my FSB speeds is 6-3-3-2.0 @2.8 vdimm. I was expecting lower latencies like you have, but no luck. Maybe my Asus board and the GeIL memory don't play as well together.
J2T
Orlando, FL
Default - 1.47 (XP1700+)
OC - 2.13
Core Voltage - 1.7v
FSB - 170
Memory - DDR340
Temps - Idle 34C
Load 42C
modenaf1
the terran system
--defualt cpu speed
1.47
--o/c'ed cpu speed
2.4
--Vcore
1.675, sometimes 1.7
--FSB
170
--RAM
340
--IDLE in °C
I AM A FOLDER!!!!
--LOAD in °C
38 :eek: i still cant belive it, even with 90° days and a volcano 9!
asj
Scotland
-Default CPU speed - 2000mhz (2400+)
-Overclocked speed - 2412mhz (fast!)
-Core voltage - 1.85 (actually 1.8 as mobo undervolts)
-FSB speed - 172mhz (cos of memory limitations)
-Memory speed - 344mhz
-Idle and load temps - 34°C idle 40°C load - air cooled!
shiltz
-Default CPU speed
1667Mhz
-Overclocked speed
1800Mhz
-Core voltage
1.85V
-FSB speed
144
-Memory speed
PC2100
idle 23C/ not sure on full load, never seen it above 27C when gaming
jonspd
Super Speedy Senior
-Default CPU speed=1733
-Overclocked speed=2415
-Core voltage=1.9
-FSB speed=210
-Memory speed=420
-Idle and load temps=36-42
asj
Scotland
Re: Re: What are you running your AMD CPU at?
-=TriX-R4-KidS= said:
-1.47ghz
-2.2ghz at the moment (need better cooling)
-1.575v
-200FSB
[email protected] 4-3-2-CL3
-37/49 stock aluminum AMD HSF
-TriX
2.2Ghz on the retail HSF!!!!!! wow! you are Extreme mate! lol!
not bad tho, but are you sure its better cooling you need?
