What are your temps and voltages water cooling?
FIRESTARR357
Just wanna see what temps people are getting and at what voltages. Trying to figure out if my temps 40c idle 45c load at 1.875v is good or should i shoot for better. feel free to put what you are running as well. I am running a eheim C1000 pump, chevette heater core with 2 120mm fans push pull both with shrouds and a maze 2 water block also 1/2ID tube.
Four weeks ago (before my system died) I was looking at...
1800 JIUHB @2550 (204x12.5)
1.95v
Load temp was 34°
Idle was 29°
Case temp was basically kept at ambient room temperature... I had lots of fans =p.
Water temp varied from 3° to about 25°.
New system should do better... after I work out my stupid Barton issue.
1700 @ 2.52Ghz
Vcore @ 2.03 Volts
I have a 5 deg C difference between Idle and Load
over this weekend my temps were 28/33, but last weekend it was 2 degrees higher
I wish we had an accurate way to compare temps. But here's mine:
2500+ @2400 MHz, 220 x 11, 1.9V
Idle: 22-24C
Load: 28 - 30C
I'm using cold water.
