- Nov 14, 2006
- Warsaw/Poland
280x (Sapph Dual-X) with i5-6600, Asrock K6, approved RAM. Several hours into a long gaming session CPU temps 40-ish, 50 is rare. System several degrees less (40 tops). GPU in low 70s (don't think it's even capable of hitting 75 no matter what I do to it and how long), even after some time under 100% load. GPU is not OCed beyond default 1020 MHz detected by the driver. Mem is not overclocked; I keep it down to 1350 from 1500 in fact. Still got some corruption in fancy light, weather or similar effects, or even texture corruption, some time into the game, as if some kind of fatigue that isn't exactly connected to the heat. In theory, VRAM cooling shouldn't be an issue. Saph's Dual-X cooler covers the whole card, so mem shouldn't be overheating without OC. Still, something's causing it. Haven't seen it before, when playing less demanding games and hitting similar temps. What else could be the problem?
Meanwhile I could add a 12cm floor fan under it just to see if keeping the temps a couple degrees down won't solve the problem. Not sure if blowing upward in the opposite direction to the card's own exhaust flow will do much good, though, with or without roof exhaust added, which I could also do. Could also put a 92mm exhaust through PCI slot holes, maybe this would do better? Case is Phanteks Enthoo pro, stock fans (20cm front intake, 14cm rear exhaust). Airflow may be poor-ish as the PC sits under the desk right in the corner of the room, so the rear of the case is close to the wall. But I still don't think temps are the issue.
