What chipset to get for a TB 1.2GHz?
Wega!
Senior Member
Denmark!
I'm gonna get a 1.2 TB (266MHz) and I'm trying to find out which Motherboard to run it on. At the same time I'm switching from SD RAM's to DDR RAM's, so that's a requirement.But my greatest concern is what chipset should be on the board? I want it to be able to archive high FSB speeds but still be stable.
So which one should I get?
1. VIA KT266
2. AMD 761 (Does this one even support DDR RAM??)
3. Ali M1647
4. A complete other chipset??
Also a recommendations of a board would be nice.
Thanks
AMD 761 all the way so far it is THE most stable and with the Epox 8k7a(+) you cant go wrong at all!! yes it supports 2 slots of up to pc2100 DDR memory, after that id get the KT266
OK, I have heard that some of the EpoX Boards supports over 2.0V Vcore, is this true? If it is, does the 8k7a support it?
