- Jun 13, 2001
Hi,
I just bought a new case and put it all together. I can't remember the name of the case, its a blue thing with plastic around it, a tower thing.. Aaanyway, it was supposed to come with five fans, but only came with four. I'm not bothered about that, I had an extra fan anyway. But what I want to know is this..
The place the missing fan was supposed to go is at the back, right in line with the heatsink. I've currently got the fan sucking air out away from the heatsink, as the case has two fans blowing in from the bottom, and two sucking air out the top. If I was to have the fan blowing onto the heatsink, that would clash with the two fans blowing air in the same direction, right? Or wrong?
What should I do? Should I have it blowing in or sucking out? Also, it seems very loud. A friend has the same case and his is quiet as a mouse. Is it something to do with that fan? Or could it be caused by something else?
Any help would be appreciated. Thanks!
Coyote.
Coyote.
