Ok guys, here's the deal. For the last year I was stuck with an old modem that came with my motherboard(yes i'm still on dial-up) anyway, the old modem was very slow, so i decided to go out and buy a new one. Anyway, I don't know if you've heard of them, but some now use what is called an AMR slot, or Audio Modem Riser slot. Anyway, I bought a Broadxent, which is a creative company, a subsidiary I'm guessing, and I pulled the old modem, popped the new one in, windows picks it up, says I need the drivers and PCI bridge or bus controller. Played with it a while, no go, so I figure well, i'll format the hard disk, do a clean install on windows xp pro, and then reinstall the drivers, that should do it. Well, i reset it, and the computer won't boot, the processor would not kick in for some reason. So I'm like what is the deal? I turn it off, then back on, it might start 1 of 50 tries. So I am thinking what is going on? Dad, knows a little about pc's says it could be the modem, I think no way, it picked it up, the processor might have been fried when i hit that reset button or something. Later, frustrated and very irratable, I decide well let's just pull this thing out and see what happens, and viola, starts right up?? Before i could hear the disks spinning, etc, so i knew there was power to everything, the cpu was not kicking in like it should.
I checked out the back of the case, and looked at the little red slider on the back of the power supply, I have a 230 watt by the way, and it is set on 115, that's what i've been using it at. I'm currently running a AMD Duron 1.1 Ghz, 512 mb's of ddr ram, 20 gig 7200 rpm maxtor hard disk, ati radeon 9000 pro, 128 meg, liteon 16x dvd, creative 8x4x32 cd-rw, Amptron mobo I think? 19 inch Mag monitor($159@best buy), and an hsp56mr modem that came with the board, oh yea, and i'm using a creative live soundblaster 5.1, it has onboard sound, and onboard nic card.
To me now, it sounded like the my whole problem was that the cpu was not getting enough juice. On my power supply, it says I can either do 115, or 230 watts. So what I want to know is if i pop this modem back in, switch it to 230 watts, will I fry this puppy? I'm posting from mom's pc right now, I know my setup may not sound like much, but i can't exactly afford to replace it, and I'm pretty fond of it, at the same time I want to be rid of the old modem(you frequently kicked off games b/c of connection, randomly booted internet, the thing does not even have xp drivers, running on win2k drivers, lol) But will I fry my comp if i crank the juice up, and the other thing, will I notice any speed diff? Sorry for having such a long post, but I really want to resolve this issue. Thanks everybody.
Btw, this new modem is for a pci interface, and is the v.92 standard
