Absolutely not. You will need a VERY good heat sink on the other side with a fan. Also, most poeple seem to think that you get better results with a misting effect over the cold-sink, or a waterfall, that way the peltier stays charged. Either way it should cool your water at least some. Good luck with your experiment. By the way, I doubt you should try it with a peltier bigger than 80 watts.
