- Jun 24, 2014
- DUBLIN/IRELAND
Hi,
there is a few kinds of hardware involved this project
1 AQUAERO 6XT (incl. temp sensors and pressure sensor)
1 HARDWARE LABS Black Ice Nemesis 480GTX 4x120mm fans on the top of the pc case
1 HARDWARE LABS Black Ice Nemesis 480GTX 4x120mm fans on the the bottom left hand side of pc case
1 HARDWARE LABS Black Ice Nemesis 240GTX 2x120mm fans on the bottom right hand side of pc case
2 AQUA COMPUTER D5 water pumps with BITSPOWER D5 Mod Kit (BP-D5MA-MBK)
1 CPU BLOCK fro 2011-3 Intel i7-6950X
2 GPU waterblock for GTX 1080Ti graphic cards SLI
I'm trying to achived best performance such low delta temperature
That's one hell of a rig you're building there and I'm sure you will achieve what you're looking for. Very similar to my build.
As far as the AQ6, I'm not sure the pressure sensor still works since I think it uses the Aquabus low and that's been disabled since updating to the newer firmwares and software. I could be wrong but I think this is the case. Nonetheless, great piece of a controller. If you want to setup curves via Aquasuite, make sure you grab some water temp sensors along with the air temp sensors that come included with the AQ6.
Hope to see images of this build once all is said and done.![]()
Thanks, I already have some air sensors build in the pc case.
The problem which I found is filling up (full of coolant) the reservoir which is on the left hand side as it's little bit higher than other one. I already have checked waterflow with aquero flow sensor and it shows me 180L/min is it good enough for this kind of waterloop?
- - - Updated - - -
yes you have right about colored coolants as I'm aware about downside of these thingsspeaking about Aquacomputer's Clear Double Protect Ultra can I use both of these :
Aquacomputer's Clear Double Protect Ultra and silver kill coil at the same time?
