What gives with these super low sandra scores?
Malakai
Fl
I borrowed a friends Kingston Hyper-X memory, 2x512mb sticks, for a few days to see how they would score on my comp at 200fsb sync @2-2-6
The scores I am pulling are so low, I just saw someone with a slightly higher FSB and worse timings hitting and passing the 3000mb/sec mark?
There has to be something wrong here, these scores should not be this low.
The rest of my specs are the same as before
q149
Japan
I was thinking the same thing when i tested mine earlier. I could not break 3k either... and it's at 438mhz 6-3-2-CL2.0 in dual channel mode.
Malakai
Malakai
Fl
I just ran again with the newest abit bios.
Scored 2848/2562
Same settings and timings all around.
Still low as hell, wtf? One stick is in slot 1, one is in slot 3. The bios verifies dual channel mode. Running the 6/6 bus setting.
Malakai
Malakai
Fl
pip said:
try disabling Dual Channel and see what it does
You can't just disable dual channel mode.
I don't feel like opening up my case and messing with my oragami IDE cables right now.
q149
Japan
I will try it in a a bit. My boot up screen also verifies that it's in dual channel mode.. it's known to lie to me though
q149
Japan
Ok. I got about 2800/2650 in 1&2 and 1&3. In 2&3 i got 2541/2313.
Can someone else with similar memory speeds check what they get?
Malakai
Malakai
Fl
Mark Larson said:
I've had up to 300MB/s difference between XP installs and EP-8RDA to EP-8RDA+. I wouldn't worry about it. They're just synthetic benchmarks anyway.
I know, but 2800/2600 is a huge drop from 3200/300 that someone in another thread got with another Nforce2 mobo at similar bus speeds.
Malakai
Malakai
Fl
gtsimmo said:
i scored about the same with my hyperX, my current corsairs only do about 100 points better.
How high did your hyperx go?
This stuff is doing 200 at max timings at 2.6 volts, without showing any signs of problems at all. And theres even a while gig of it :eek:
-=TriX-R4-KidS=
Indiana University, USA
ive got mine at DDR400 5-3-3-CL3 (crap timings but this is SPD 6-3-3-CL3 DDR266)
i dont have any trouble getting over 3000....just re=-ran the bench and get 3047/2831. im using the v14 BIOS.
and the RAM is 2x256 and in DC.
i guess you could try loosening the timings and seeing what that gets you.
-TriX
Malakai
Malakai
Fl
-TriX
Thats really wierd, what OS and version of Sandra are you running?
Woody29
UK
hi...
i maybe wrong on this but i think you have to be over 200+fsb to get around 3000mb/s bandwidth or over.
i'm able to get around 3300mb/s but thats at 220fsb
Woody29
UK
hi trix
ok, but the chances of getting 3000mb/s+ will be difficult to reach cos off the difficulty in achieving the timings you mentioned?
especially for it to be stable?
-=TriX-R4-KidS=
Woody29 said:
hi trix
do you want me to take photographical evidence? and it is stable. ~1hour of p95 is stable enough for me. i havent run p95 longer than that and i dont need to.
"I have never even heard of anyone with CAS 1.0."
twas a typo. sorry.
-TriX
-=TriX-R4-KidS=
alright just benched again and screencapped it:
sorry about the large size. I am in a hurry.
and i thought everybody who was running DDR400 was getting 3000mb/sec bandwidth? i guess thats not the case. maybe i have magical RAM : /
-TriX
