- Dec 17, 2000
- InSane Diego, California USA
Okay, I cannot figure out why my temps keep climbing the way they are. I live in San Diego, CA. USA. where the current air temp is around 80 degrees F. But my cpu temp as I write is at 104 and the mobo is at 91. I have tried relapping my GORB which I have modified by removing the OEM fan and replacing it with a 60mm box fan attached atop of it. It has done a decent job so far except now. Everything, cooling wise and speed and voltage wise is the same as I have been running for the last 5 months or so. I have (2) 80mm fans mounted low blowing in onto the PCI cards, another 80mm attached to the bottom of my PSU exhausting out, a 3" 120v Radio Shack cooling fan exhausting, positioned at the rear 2/3 up from bottom of case. I also have replaced the HSF that came OEM on my GForce 256 with the OEM HSF that came with my PIII600EB flip chip. And then I even went as far as to place an PII350 slot 1 fan atop the GPU and ram chips. &*#@ ! my temp alarm just sounded temp now @ 105 set for 104. I am miffed. 600 eb @657 FSB @146 Vc1.65 I/O @3.456 I would greatly appreciate any and all explanations as to what is happening here. Goto go and let this thing cool down.
